Problems With Excel? "Failed to set Excel running"
Has anyone run into the following problem with Part or Expression Spreadsheets?
Error:
I closed UG when it froze trying to connect to spreadsheet, now it won't connect to spreadsheet for any of the parts I try.
If you've seen this problem do you know if there is an open bug on it for EDS? If not then I can have them add that along with the other bugs I've found in my short time with UG.
Michael
Error:
Michael
RE: Problems With Excel? "Failed to set Excel running"
Open Excel separately and go to Tools -> Add-Inns
Uncheck the UG box on the list and exit Excel.
Then restart UG and try connecting to Spreadsheet.
In some cases even if you exit excel you have to shut down the process using the task manager.
Michael
Is there anyway to solve this problem?
The version of excel is dependent on the version of UG. If you go to uganswer and ask about Excel verions, there should be a documnet or SFB covering it.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
For UG V18.0.1.1 and BELOW you must have Excel 1997 or Excel 2000 installed. For V18.0.1.2 and higher, Excel 97, Excel 2000 and Excel XP are supported.
Ben Loosli
Ingersoll-Rand
