bearing adjustment of pump
We have a water pump(Sulzer)that the located bearing in this pump
are pair taper roller bearing (31319) which mounted face to face.
The floating bearing of this pump is a NU bearing.
For repair this pump we need change the locating bearing.
In simple way how we can calculate the length (tolerance) of ring between outer rings of 31319 bearings and how we can adjust the axial internal clearance of bearing pair 31319.
RE: bearing adjustment of pump
Good Luck, Flowman
