Carbon Steel Stress
Carbon Steel Stress
I want to calculate teh thickness of a carbon steel vessel with e=P.r/K + CA (corrosion allowance)
but I don't know the value of the hoop stress K for Carbon steel
RE: Carbon Steel Stress
for internal pressure on page 22,
t = PR / SE+ 0.4P
WHERE)
P = DESIGN PRESSURE OR MAX ALLOWABLE WORKING PRESSURE
S = STRESS VALUE OF MATERIAL PSI SEE ASME PATE D
E = JOINT EFFICIENCY
R = OUTSIDE RADIUS
D = OUTSIDE DIAMETER
t = WALL THICKNESS
C.A. = CORROSION ALLOWANCE
