Display of Cross Section Arrows
I am having a problem when making cross section views. Pro/E is giving me a message that "Cross-section arrows will not be displayed".
Would anyone know why this is happining? I always would want the arrows so I am not sure why they dont show.
Thanks so much, this is driving me nuts.
JFollo
JFollo
RE: Display of Cross Section Arrows
At the risk of asking annoying questions - are you picking the parent view for displaying arrows when prompted by Pro/E? This message kind of sneaks in quick on the message bar right in the middle of the view creation process.
If you are following the correct procedure, I would suspect that it is a config.pro issue.
cheers,
JW
I am picking the parent view for the cross sections. It is actually happening on all of the drawings for my assembly.
Weird
I will check my config file and I have checked my drawing setup file and all seems correct. If I cant figure it out today I will call PTC and post the answer, if they know, for anyone else that might have the same problem.
Thanks again
