Using information in Ug
Hi all,
While using information -object
If I select a line to get information
In the information window ,i am getting
In start point and end point there is
Xc
Yc
Zc
also
X
Y
Z
what is the difference between these two,
both are giving the same information any way?
Karthikeyan.J
RE: Using information in Ug
If you move your WCS
then you would get different result.
XYZ from absolute WCS
XC YC ZC from current WCS
Thanks Berserk,
It was useful.
regards,
Karthikeyan.J
