TODAY WINDOW SYSTEM VARIABLE
Hi Guys n Gals
Does anyone know if there is a system variable that controls the path that shows where your today window looks for your in-house bulletin board.
I know how to find it via the today window itself, but I need to find the path out using a lisp routine.
Any Ideas??
The Welshman
RE: TODAY WINDOW SYSTEM VARIABLE
This was an interesting post ...
What I found ...
Is the editcadmgr.htm under "C:\acad200" ...
I opened it in WORD as plaiin text and edited at will ...
I also created a blank one from scratch in NOTEPAD.
Type in ...
HELLO RICH...
BYE RICH
And saved it as z.htm
And saved it as z.txt
When I browsed to it ...
And saved the path ...
The message came up differently depending on which file I pointed to ...
But the message stayed open for every session of AutoCAD until I deleted the file.
I didn't find the variable that loads this but the messenging seems to work like a charm. What exaclty are you trying to accomplish?
