Msc(Foundation Engineering) or Msc (Soil Mechanics)
Which of these two Post-graduate degrees carry more weight. I am a recent civil engineering graduate and i am considering embarking on either one of these courses.Has anyone done either of them?
Secondly, has anyone done any soil stabilisation work with PERMAZYME-11X
RE: Msc(Foundation Engineering) or Msc (Soil Mechanics)
As to your second question, Secondly, has anyone done any soil stabilisation work with PERMAZYME-11X - the specific answer is 'No'. But it is likely that I have worked with functionally similar proprietary chemicals. Can you give us a basic understanding of what's in the "snake oil"? Ammonium/calcium lignosulfonate? Potassium chloride? Sodium chloride? Sulfuric acid? (Am I close?) What does the manufacturer claim as the process by which the "treatment" works?
I did some research on permazyme, which was almost from scratch as there is no published reports or papers on this. The manufacturer was very unwilling to reveal the contents of this product.
Permazyme is a water based enzyme stabiliser consisting mainly of organic compounds( hence biodegradable) and surfactants, with primary functions mainly being:
a)lowering the surface tension of water hence aiding compaction
b)creation of crystalline structures amongst individual soil particles through biologically catalysed reactions.
The organic compounds it contains include CaCo3, compounds of iron amongst others.I know for sure that it doses not contain lignosulphates like other stabilisers
Now for permazyme to work the existing clayey soil has to have some organic content. This organic content is usually determined by its C.E.C.
Clay by itself possesses a negative charge, naturally it'll attract positive charged ions. My work suggests that there are a lot of loose positively charged ions in permazyme, thus a bond is created with the clay particles when introduced
This information was not supplied by the manufacturers. All they provided was the functions of permazyme and a rather shoddy schematic of a lock-mechanism.
you may ask any further questions on this enzyme stabiliser
The "hammer" is for the snake oil salesmen that are pushing this product. Without a coherent technical explanation of how their product functions - supported by solid chemical and geotechnical explanations and documented proof the product actually works - I'd tell them to get lost.
Vague claims of efficacy are meaningless to a design engineer - and can get you into hot water. I've seen lots of these claims - most are from a dark, smelly place. Require proof of ingredients - even to the extent of signing a nondisclosure agreement. Just don't sign a non-criticism agreement...
I am a heavy equipment operator for a county in California.
We have been using permazyme for few weeks on some of our dirt roads.
I am not impressed with it. It seems it work if there is alot of clay in the dirt.
I think if you used it then cap the road with chip seals or asphalts then it probably work very well.
We have not and are not going to do this with these roads.
The roads we have done are high use roads. May work better on low use.
We used it in hopes to stop the roads from unraveling. wash boards are already showing.
I would like try some dust-off to cap the road and see if this would help slow erosion from vehicle travel some.
Dust-off has been used on other roads and they look better than the one we just did.
I would like to know exactly what is in permazyme. I sort of smells like bad wine.
I hope you're not in northern California - could spoil your interest in "the fruit of the vine."
biloxi26:
How can I contact the manufacturer of Permazyme?
Please see FAQ731-376 by VPL for tips on how to make the best use of Eng-Tips Fora.
I attended the M.Sc. in Foundation Engineering course in Birmingham last year (only the autumn term as an international student from Denmark though). The course teach you both soil mechanics and foundation design among others. I think the course is really good, and I hope that you will attend it. You'll get a good allround knowlegde in all geotechnical aspects.
It you have any questions about the course, look at the web site http://www.eng.bham.ac.uk/civil/pg/foundation.htm where you'll find a lot of information about the course and some e-mail addresses for the staff.
Cheers
http://www.co.missoula.mt.us/EnvHealth/AirQ/AdvisoryCou...
a chemist at Permazyme described the treatment as containing only an enzyme and is not a calcium chloride product as had been circulated, hence nor is it likely to contain much calcium carbonate. One for the pedants - CaCO3 is an inorganic rather than an organic compound (chemistry degree showing through now).
The enyme is apparently produced from fermenting sugar beets (which probably explains the smell reported by ThomasD. My feeling is that the mechanisms described for this treatment (and it apparently has other uses besides the one under discussion here in bioproduct stabilisation) probably work but for a situation like ThomasD describes will be of little use.
There is mention of dust forming '..when the top layer gets wet which breaks up the bonds a bit' or when heavy vehicles '..crush particles against the surface'. This says to me that the bonds formed are very weak - an outdoor road that doesn't like rain? Might as well be a completely unpaved track then, surely?
For those trying to find out more this may be of some use:
http://chin.icm.ac.cn/lit-guid/prepare.html
While I haven't tested this material, I see nothing at present to recommend its use to "stabilize" clay soils. The calcium carbonate won't react much with the soil - unless it's acidic - so there's little opportunity for cation exchange with the sodium ions in the clay.
I'll keep my distance from it...
What is the cost benefit in not providing a paved access road? Clearly to be of much use it has to applied in large amounts to ensure penetration, and given that for many construction sites the plant is on hand for provision of paved roads it seems uneconomical? Perhaps someone nows figures that may be of use.
I have also seen metal plating used in this situation (temporary runway type material) - is the dust level associated with this sort of material so high that it precludes use?
Finally - I think this thread now needs renaming to reflect the Permazyme discussions!
You could probably do the road for as little as $200 or $300 of cost, and charge $2,500. That's less than the haul cost for imported materials on many jobs. The motivation to push this stuff is pretty clear -
Yeah, we should have started a new thread...
