About cleaning the casting parts with ultra-sound wave?
Hi:
Do anyone have the experince about the cleaning the casting parts with ultra-sound wave before these parts are painted.
we plan to install a new painted workshop, in the form time, we clean the casting part with acid, pure water and other chemical to clean the casting parts( aluminum), now I heard that clean these parts with ultra-sound wave also works, but i am not sure, and have no any idea about it. who can share some experince about the cleaning, the procesure, the check and so on?
Thank you.
Best Regards,
forward
Thank you.
Best Regards,
forward
RE: About cleaning the casting parts with ultra-sound wave?
-mechantaeus
The basic principle is that a liquid of sorts is 'shaken' by means of some kind of actuator (ultrasonic transducers).
When the energy that is put into shaking the liquid at frequencies above 20khz reaches a point when it exceeds the adhertion forces of the liquid tiny cavities (voids) occure.
These voids grow over a few cycles of the actuator until they cannot be sustained any longer. At this point they collapse releasing huge amount of energy on super local spots. This energy is in the form of heat and pressure.
The way this process cleans is that the dirt is physically bombarded off the meterial by these millions of collapsing voids.
The energy can be enough to cause corrosion of the surface of substances like alluminium and other metals (only after long exposure). This is illustrated by the corrision of ship propellers and pump impellers.
In summary, ultrasonic cleaning can be very effective in the cleaning of intricate components and is widely used in industry eliminating the use of harmful chemical cleaning.
