In the WPS for Welding a ASTM A-333
In the WPS for Welding a ASTM A-333 GR 1 & 6 pipe for carry ammonia anhydrous liquid at -30 deg C, we used a E-6010 for the root pass and a E-7018-1 H4R for the fill and presentation layer.
After the clean of the root pass we heat the weld at minimun 130 deg C with a torch.
In the PQR we got the Folllowing: 1) Rx: No defects
2)Tension test: 79000 and 76000 psi tensile strength, 3)Hardness and tension bend: OK 4)Charpy at -35 deg C: 45 Joules.
What Do you Think?
The values of the impact test are low or what?
What Do you Think?
RE: In the WPS for Welding a ASTM A-333
