Membrane for H2 seperation
I am looking for a membrane to seperate hydrogen from its mixture with nitrogen and some small amount of other gases.
RE: Membrane for H2 seperation
Speaking professionally (I work for Air Liquide, so I have to skirt the forum rules here) you have not given enough information to determine if a membrane would work or be economically viable.
A metal membrane (Pt/Pd) separates great, but is not cost effective at much more than bench scale.  A polymer membrane might work, but have a more limited temperature range and the "small amount of other gases" might be a show stopper if the other gas is say methylene chloride or HCl.  This also becomes a cost issue, as the systems have a minimum size to be worth the manufacturers cost
Dave Hasse
AIr Liquide Research
dave.hasse@airliquide.com
In terms of hydrogen permeabilities the relationship is as follows:
Nb>V>Ta>Pd>Fe>SS304>Cu>Pt>Al (T=352 deg C to 727 deg C)
Buxbaum, R E and Kinney, A B Ind. Eng. Chem. Res. 35 (1996) 530
