Installing multiple SW versions on one computer
I'm working for a company that uses a network license of SW 2003. I have another client that only uses 2001+ and another that uses 2001. If I have 2003 installed an then install 2001+ or 2001, when I launch 2003 for the network license it tries to use the Serial Number of the 2001+ install and says I need to enter the REG code. If seen people at work have multiple installs on their machine but I can't seem to make it work. I've tried this 3 or 4 times without success. Does anyone have any ideas on what is going wrong or how I can work around it.
My computer is a Dell Laptop running Windows 2000.
Boggs
Boggs
RE: Installing multiple SW versions on one computer
But with SW03 your Reg code is different than the SW01+ and SW01. Being on a SNL, I don't think you have to enter that reg code in. It goes by a FlexLM file. So having multiple copies on one machine is not possible unless you have all three SW's install on the server and a FlexLM file to match.
I maybe wrong so if someone understands SNL's better than me. Please chime in here.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
I install 2001+ before 2003 in differents folders
maxb
hee hee,,, and with sw04?
Flex is awesome! Is flex GONE in '04, or just revamped to use SW's version of flex?
