STAT! Dialog Boxes
STAT! Dialog Boxes
I somehow lost dialog boxes (AMextrude,mtext etc.). Entries are prompted on the command line. What variable or setting do I need to change to return to the dialog boxes?
RE: STAT! Dialog Boxes
Set CMDDIA = 1
Also check to see if FILEDIA = 1 while you're at it.
Also see if FILEDIA value is set to 1....
CMDDIA stands for Command Dialog Boxes... and
FILEDIA atands for FILE Dilog Boxes...
There are many other System variables you can paly with to ease your life while working with MDT or AutoCAD.... The list is available in HELP... just see in SYSTEM Variables..
n' Voila you've got what you wanted....
Sumit....
