Drawing Formats and prompted notes
Hey everyone,
I use 2d drawings quite a bit and I use the prompt tables with the formats that make beginning a new drawing very easy. I would like to use NOTES on the title block that are filled using prompts instead of using TABLES. I know notes work well with the scale (&scale) or the drawing name (&dwg_name) but I would like to create my own prompts that the user has to type in himself. Any suggestions would be appreciated.
Irv
Irv
RE: Drawing Formats and prompted notes
We use a system where the drawing title block information is driven by model parameters. If these parameters fields in the model are not filled in prior to starting a drawing, Pro/E will prompt the user to enter the information before any drawing views can be placed. Is this what you are looking for?
Both our models and title blocks contain the following:
&part_number
&dwg_number
&rev_number
&model_name
&title_line1
&title_line2
&material
&ecn
&quantity
&eco
Hope this helps,
JW
I've been looking at these parameters and their functions and it looks like thats what I need.
Thanks a lot.
Irv
&revision becomes &proi_revision
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
