Code 150 and 151 pump ports
I am investigating a Haldex brand gear pump that has "Code 150" or "Code 151" ports. I am trying to source hose fittings or adapters.
These all employ a four bolt, equally spaced, mounting bolt pattern around a central port.
The dimensions are:
Code 150. M6 threads
Inlet: 40mm BC, Ø20mm port
Outlet: 35mm BC, Ø15mm port
Code 151. M8 threads
Inlet: 55mm BC, Ø26mm port
Outlet: 55mm BC, Ø18mm port
Any help to find fitting for these ports is most appreciated.
The dimensions are:
RE: Code 150 and 151 pump ports
Thanks for the response, but these are not Code 61/62. Those have a rectangular bolt pattern and the ones I am needing fittings for have a circular bolt pattern.
