Algae screening
Algae screening
I am designing a large diameter raw water transfer pipeline (2.6 m diameter, flow 8.7 m3/sec (140,000 gpm)). The pipeline is supplied from an open surface impoundment reservoir. I am proposing to use twin 1.2 m diameter submerged discharge sleeve valves at the outlet from the reservoir to the pipeline.
I have just learned that under some conditions the reservoir suffers severe algae growth. I am concerned that the algae will cause blockage of the small ports in the sleeve valves also we need to remove algae before the raw water enters the pipelines.
I am therefore proposing to install screens upstream of the sleeve valves. The pressure upstream of the valves is 50.m head (5 bar, 73 psi). The screens will need to be self cleaning.
The alternative is to replace the ported sleeve valves with hollow jet type valves and provide low pressure screens downstream of the valves.
I am looking for advice/manufacturers of suitable self cleansing screens.
brian
brian
RE: Algae screening
Another outside possibility would be to control the algae growth.
RE: Algae screening
An ideal algae filter is a tilted coanda effect screen. It is commonly referred to as a tilted wedge wire screen.
Contact Mark Hoyack with Krebs Engineers of Tucson, Arizona. They are the best when it comes to hydrocyclones and screens.
Todd
www.oxilume.com
todd@oxilume.com
