PERFORMANCE CALCULATION
I am now working for small capacity industrial boiler. The capacity is around 90TPH superheated steam. This is a trial project to us and I am trying to figure out what basic design calculation am I going to use. I am looking for a better formula in computing the performance calculation.
82264
RE: PERFORMANCE CALCULATION
could you clarify what you want, mechanical or thermal performance ?
John
I agree with johnnymist2003, you need to be a little more specific.
If you are looking at performance, you should probably check out ASME PTC4 and PTC4.1.  This will give you all you need to complete a boiler performance test.
