Exporting configurations to .STL files
I may be doing something wrong but I have a part with multiple configurations that I need to save as an .STL file.
When I do the STL file is always of the "in-use" or "last saved" configuration.  I need STL's of all the configurations.  Help.
RE: Exporting configurations to .STL files
Try making scratch files of your models, exporting the configs as parasolids and reimporting into new parts si there is only the single config.
Good and evil: wrap them up and disguise it as people.
It is impossible to make stl files of the configurations.
i think it is the same case in all the cad softwares
CNKK
"HOPE : Sees the Invisible, Feels the Intangible and Achieves the Impossible"
Thanks.  I found that I have to export each configuration separately as an STL.  To use in an assembly  I would have to import the file as a dummy part them export the assembly in stl format.  Seems to work fine that way.
