changing hatch patterns in autocad2002
regarding autocad2002: to change hatch patterns, you have to go into the bhatch dialog box and reset properties. is there any way to pick on an existing hatch in a drawing, a hatch that's already been made, and have all the properties in the dialog box reset to match that particular hatch so you don't have to set each property individually to hatch in another area with that hatch pattern? if you know, feel free to respond to me at pcourteau@discounttireco.com, and thanks for your time.
RE: changing hatch patterns in autocad2002
1. bhatch the objects, using the default pattern, then when done, use match properties, pick source pattern then pick all hatch to change.
2. when in the bhatch command window, use the "inherit properties" button to "copy" existing hatch pattern before applying new hatch.
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
