Cast Iron Boiler Section Sealing Methods
Some Cast Iron Boiler Mfr's (Burnham, Peerless, Others?) use metal push nipples to seal the water passages between adjacent boiler sections. They infer that this is a superior sealing method compared to other manufacturer's (Weil McClain, Smith Boiler, Others?) who use high temperature elastomer sealing gaskets. My understanding is that the differences are not significant with 180-200F hot water applications, but when generating low pressure steam in the 215-250F temperature range, the elastomer gaskets are much more prone to failure, and need to be replaced periodically, requiring boiler disassembly etc. I know that Smith Boiler has had problems in the past with gaskets, and have upgraded gasket systems, but I don't know how the upgraded gaskets have performed. Are there any cast iron sectional boiler opinons out there who can offer their experiences regarding reliability of elastomer gasket systems and metal push nipple sealing methods. Conjecture is okay, but actual experiences are even better. Thanks in advance.
RE: Cast Iron Boiler Section Sealing Methods
Back then leaking occured when the boilers were shut down for the summers and such leaks appeared to stop when heating resumed.
From recollection one of these boilers was comprised of over a dozen sections. It was unusually long for such boiler and every summer the leak would reappear.
Since such boilers were under warranty at the time, the manufacturers would take care of the leaking problem as it was very obvious of potential product liabilty claims.
I have to think that by now such situation have been resolved but from your inquiry it seems to persist.
