how to NOT undo pan and zoom
When doing commands, I frequently zoom and pan to make sure the correction looks right and then when trying to undo, I have to undo all the panning and zooming before I can undo the last actual command. Is there a way do disable undo-ing pan and zoom?
RE: how to NOT undo pan and zoom
Flores
Flores
I want UNDO to do just that, whatever was done, undo it. If I've panned, pan back, if I've changed a system variable, change it back. Proper use of the UNDO command (not just U) by placing UNDO MARKs, and using UNDO BEGIN and UNDO END in lisp functions goes a long way in efficiency.
