Shore hardness conversion to modulus of elasticity
I'm trying to get the conversion factor for determining the modulus of elasticity from the shore hardness of neoprene sheeting. Please Help!
RE: Shore hardness conversion to modulus of elasticity
Not only will fillers affect modulus, the base polymer will change modulus. A Shore A 65 nitrile won't have the same modulus as a Shore A 65 fluorosilicone. The best way to find the neoprene modulus is to tensile test it.
I work for Raufoss Composites in Norway, and I would to ask whether it is possible or not to receive any technical information about:
Elastomers in dynamic applications
Effect of frequency, strain and temperature
The reason why i ask this question is that we are working on a special case, where a 2 gram
piece of detonation unit in a missile needs a damping element of rubber in front and at the rear during the phase when the missile hits its target. The system is exposed to a g-force of 90.000 g during a very short time of 0,03 ms (about 33.000 Hz).
Do yua have any data describing how the e-module is affected by the frequence? We consider natural rubber, neoprene, butyl and silicone. The actual temperature is -35 degr c to +60 degr C.
Thank you in advance
Best regards,
Arild Hansen
You should contact RAPRA in the UK. They publish a book 'Dynamic Mechanical Analysis for Plastics Engineering' which covers DMA data (storage and loss modulus) on temperature sweeps and frequency.
Phone 0044 1939 250383 www.rapra.net
Speedy
If it helps, I am assuming that I will be nowhere near the maximum loading for the material. THANKS.
