plot to a png file..how to change dpi?
in autocad lt 2000, i'm saving my dwg plans as png files and i've created custom page sizes but i can't change the dpi setting..it's stuck on 100dpi. can anyone help?
RE: plot to a png file..how to change dpi?
What are you for a media?
Is it "Sun Hi Res - 1600 by 1280"?
It's the same problem with all "paper" sizes, Sun, Super, XGA and VGA..I can't raise the resolution above 100dpi..
Can I ask how you know it's 100dpi?
Are you using "photoshop" to list the properties?
OR are you using "MS Photoeditor" to list the properties?
Or is it something within AutoCAD that gives you that info or what ... ? That might give a clue to how to raise it if possible at all.
