Dear all, Im having problems set
Dear all,
Im having problems setting up a model in CSI SAFE.
Ive constructed a 3D Fe model in etabs of a reinforced concrete structure consisting of large span floors supported of thick wall walls.
On exporting the model to safe I have to set up the support properties. Im having trouble getting the beam support moments in SAFE to correspond with Etabs. I think its something to do with the connection fixidity.
Im setting up the wall properties correctly (i.e correct height of wall activated above and below the support). I think it may be something to do with the wall supports assigned beam properties.
Can anyone advise what beam properties (if any) should be assigned to the wall support in safe.
Gary
Gary
