Transparent & high heat
I am looking for a material that is transparent and does not deflect @ temps below 150C. The piece only needs to be 200 x 100 x 15mm. Something with Lexan's strength and transparency and can withstand heat like ultem (and of course, the cheaper the better!). It can be slightly translucent; Ultem would be ideal, but 10mm+ it becomes too opaque
RE: Transparent & high heat
