Ultimate stress in a pressurized fuselage
As a first post in a very interesting forum, I would like to ask 3rd party repair engineers what they use as an ultimate static stress (tensile) when designing “scab patches” on the fuselage skin. I think using Ftu leads to an over dimensioned repair when you consider that the fuselage is basically a thin walled tube in bending which fails in compression and leaves lots of opportunity to allow for local yielding in the upper shell. I think Fty is more appropriate. (reasons will come later)
RE: Ultimate stress in a pressurized fuselage
Usually 1 gage heavier and based on Ftu. We don't have access to the stress reports so we assume that the worst case scenario would be Ftu failure.
The fuselage by itself would fail in compression, that's what the stringers and frames are for.
T
That is just my point, if I design to Ftu I will more than often require more than the 3 fastener rows that are shown in Airbus and Boeing SRM’s, going 1 gauge thicker means I have a larger bending offset in the fastener and this leads to a reduction in the fatigue life. As you say the fuselage fails in compression, these compression stresses do not approach the order of magnitude of Ftu.
As a matter of interest, do you have more experience with Boeing or Aus aircraft?
Lots with Boeing, MD, Sabreliner, Hawker, Bombardier, etc.
If the doubler is too thick you can use more than one thickness and stagger the last fastener rows.
Or taper the edges so the last fastener row is going through thinner sheet. Etc...
T
When load data is available, we will size to that, however, from what I remember, fatigue would sometimes drive the need for an additional fastener row (i.e. taking it out to 4 rows, such as astroclone said).
Nert
1. The reason in the first post, local yielding in the thin walled tube (fuselage) will not permit the tension stress to go beyond Fty, it will always find a way to include more effective tension area.
2. Modern day jet liners (including those using Glare) are designed to a (undisturbed area) fatigue life of 90 to 110 N/mm² fatigue stress converting this to an ultimate static stress (Nz = 2,5 and 1,5 delta P) you obtain a stress round about yield.
3. (maybe a little weak but) Linear FEM models do not obviously include the inelastic behaviour of the structure, reducing the ultimate elastic stress (Ftu value) using Ramberg-Osgood you get a value under Fty when considering 2024 T3 properties.
Is there a DER here that won’t sign off a repair when I give him these arguments?
I can give you a reason for not using Ftu: when I put holes into the structure for the fasteners, I have reduced the net section tension area of the original and so I get automatically a MoS less than 0 and a reserve less than 1.
Mike
PS sorry if I’ve went on a bit.
When designing a repair, I question the assumptions in the analysis more often than reaching for a third row. I usually try to show that the skin stress in the repair / antenna installation has been reduced below 12 ksi or so (85 N/mm2).
85 N/mm2 = 12 ksi, and 12 ksi * 0.032" sheet = 384 lb/in. Two rows of MS20470AD4's are sufficient.
Sometimes the stress concentrations around repair cut-outs are staggering, and then the design gets "rivety".
I haven't seen any airframe techs "flip out" yet, and the repairs do get signed out.
BTW, why would anybody want to machine a thin edge on a sheet? Bond two thin ones together, and one is longer and wider than the other, to get the same effect, right?
STF
Nigel Waterhouse & Associates
Aeronautical Consulting Engineers
Transport Canada and F.A.A approval & certification of fixed and rotor wing aircraft alterations: Structures, Systems, Powerplants and electrical. FAA PMA, TC PDA.
n_a_waterhouse@hotmail.com
Are we saying that the fuselage will fail in compression at the lower lobe due to bending?
Why won't the fuselage fail in tension on the upper lobe/crown area? Likewise, why won't the fuselage fail in tension in the hoop (circumferential) direction due to
pressurization "fatigue"?
Alex
I've seen a few failures of fuselage skins in my brief time as an engineer (4 years). All of them have been due to loads normal to the skin that had nothing to do with the original type design. Either it was from a mechanic sitting on the nose as he replaced a windshield panel, or from floppy antennas that had no business being installed on an aircraft,
STF
I agree with Nigel. The least conservative thing you can do and get away with is copy a local fastener pattern. If you're repairing an airplane and you don't have access to the stress notes, don't make the repair weaker than the original design.
I was reading our 717 SRM on how to size say a rectangular repair doubler for skin that was trimmed out or blended out.
I am wondering if you find the method too conservative:
Take the case where you have excessive blendout due to impact damage. The skin that's blended out has dimensions L x W x T where T=max. thickness of skin blendout.
To size the doubler itself, you pick a material and gage whose Ftu*t of the doubler is greater than Ftu*t of original skin. This ensures that the doubler can carry the original factory skin tensile loads.
Then, you find out how many fasteners you need on say, the "L" edges (two edges).
# of fasteners along "L" edge = (Ftu * L * T *1.15)/(joint allowable found in MIL-HDBK5)
Repeat the same thing along the "W" edges by replacing "L" with "W" above.
Now, you've sized your fasteners to be able to transfer ultimate loads (in addition to a fitting factor of 15%).
Do you think this method is too conservative? Or must an airline repair engineer abide by it at all times when sizing a a doubler?
Frankly, this method seems like the single one any repair engineer would ever need (with no fatigue considerations) at their job, even though it may seem rather conservative.
It's a lot easier to make 2 doublers than to machine steps and tapers and fingers and so on.
As a repair engineer I can't justify doing anything less than an Ftu type repair as stated above. We don't know the loads and manufacturers have a death grip on their stress reports.
Our company even used to make corporate jets and when we repair our own airplanes they fight us for the stress report.
I did manage to do a cool crippling analysis one time, though using the company stress report.
Good times,
T
Do you do a Ftu calcuation similar to my last reply above? Do you always design your repairs to Ftu?
What kind of fatigue calcs. do you perform?
Cheers,
Alex
Your method is certainly the most conservative way to repair: w = Ftu*t (where w is running load in lbs/in). The 15% "fitting factor" may be a little over the top. We normally only apply a fitting factor to single pin joints.
The second method which Nigel alluded to and I commented earlier, requires you to read the airplane's structure. By analyzing the strength of a local, original joint, w = (Pall x # of rows)/spacing, you may find some relief in sizing your repair. As stated earlier, you need to read the structure and pick the right joint.
There are a lot of good posts on this thread about many other things that should be considered when designing a repair. Since you're dealing with a 717, Boeing Customer Service has a checklist for engineers doing repairs on their web site.
“Reading” the airplane structure and copying what’s there is fine, but again you have to be convinced that the manufacturer has put the joint at the most highly stressed part of the aircraft. Copying and adapting the SRM is the better solution but unfortunately the repair you require just happens to be missing most of the time.
I think I’ll continue using Fty to size the repair.
At Boeing, we sized structure to ultimate loads (1.5*limit) or whatever the Boeing requirement was for static analysis. For fatigue analysis, we brought the load down to limit if we did not run fatigue loads.
If you do not have access to loads, then you must size to the capability of the structure, which I agree, tends to be conservative. However, an aircraft rarely "operates" at ultimate load (if ever) so one could make the argument to use Fty since this is closer to the "operational" loads.
To conclude, at Boeing, we used the most conservative analysis possible unless weight became an issue. That way, you knew the structure was good.
Hombre
I am also talking about doing the static analysis. Without knowing the actual loading it is impossible to determine the fatigue life or inspection interval. What you can do however, is, by following good design practise, ensure that the repair doubler is optimised from a fatigue point of view, e.g. do not end on existing fastener positions, avoid installing too thick a doubler, take the doubler all the way around the corner and so on
What interesting forum!
Fristly you always should desing structural repairs acc.
SRM or following mfg. indications. it,s the best method,and the safer too.
The first question of sheet metal guys is why they put only two rows and we,ve to instal 3 or more. Well due cheminal milling , skin panel has different thicknes you
know.the joint has the thicker one you can install 3/16
rivets in.080 TH. sheet but never below .040 all my
handboock tell the same.
Perhaps you can desing a doubler made of two different
thicknes sheet based in Ftu but take acount the knife effect between skin TH. and diameter of rivet installed
escuse my basic English. I,m trying to improve it.;))
I think that one important thing that is forgotten is the FAR's 25.301, 303, 305, 307. FAR 25.303 states that a 1.5 factor must be applied to the limit load during design. Even though the normal operating or limit design load maybe less than the actual Fty. The 1.5(limit load) may be greater than the Fty. Therefore, since you do not have the actual limit load or normal operting load of the skin panel, you must use 1.5Fty or Ftu (conserviative)in order to meet this FAR's. As a DER, showing compliance with the FAR's or CFR's is req'd.
1. Ftu
2. The load capability of the applicable SRM repair, or
3. the load capability of adjacent skin production joints.
Obviously all other rules including doubler thickness, stepping/tapering and appropriate fasteners apply.
On a different note -I must say that I am a newbie to this forum, but really enjoy it. I have noticed that I have to read my own posts a few times because what I am thinking doesn't always come out on the keyboard the correct way!! Please let me know if any of my posts don't make complete sense.
Dave081069:
-What do you mean by point #2? Do you just mean following the SRM?
-There's a dichotomy between the first two points and the last point. If you look at a skin joint on the 717, you'll see two rows of fasteners. The skin repair section in Chapter 53 mandates a minimum of 3.5 rows (with finger doublers) for permanent repairs. If you were to use Ftu, you'd probably end up with 5 or 6 rows!! What gives?
737eng:
Do structures DER's have access to OEM loads? I wonder what basis you use to sign those 8110's. Do you simply ensure that the repair meets Ftu, and that it follows general durability guidelines? I am curious as to whether the DER's job leans more towards verifying calculations, strength, etc. (i.e. engineering) versus ensuring actual FAR compliance (i.e. regulatory paperwork)
Does bumping up Ftu by 15% (the fitting factor) apply to all structural joints?
Cheers,
Alex
#2 is really about using the SRM repair as a method of determining the loads required for a modifed repair i.e. a repair in a location or configuration where a standard SRM repair cannot be accomplished.
When you say that your doubler will break if you assume the structure works at Ftu due to the fastener holes, wouldn't going the standard "one gage up" account for the reduction in net tension area?
In one of your replies above, you mention three points to design to Fty instead of Ftu:
Quoted:
"1. The reason in the first post, local yielding in the thin walled tube (fuselage) will not permit the tension stress to go beyond Fty, it will always find a way to include more effective tension area.
3. (maybe a little weak but) Linear FEM models do not obviously include the inelastic behaviour of the structure, reducing the ultimate elastic stress (Ftu value) using Ramberg-Osgood you get a value under Fty when considering 2024 T3 properties."
Could you please enlighten me a little and digress a bit on those points? I am a little lost.
Alex
Thanks for your reply. In my measly 15 months in the biz, it's never come up that I've had to use the SRM to attempt to back out the loads. Usually, if there's an SRM repair for that area, we use the SRM repair. If not, we figure out the ultimate loads and size the doubler/fasteners accordingly. I am wondering if you could share your experiences on the issue.
Oh yeah, do you also have any comments on my second point in my last post?
Cheers,
Alex
I slight misunderstanding, I wasn’t talking about the doubler, I meant the original structure, which you obviously can’t change, unless you’re thinking of hot-bonding a doubler to it.
As to the reasons:
Progressively bend the fuselage so as to develop tension in the upper shell and compression in the lower shell. The upper shell stresses will increase linearly to the Fty value in the crown area. When they reach this value the crown area will in effect increase due to local yielding but the stress will remain constant. This area will con-tinue to increase until the fuselage fails in compression in the lower shell. The fuse-lage is simply not massive enough to go plastic in the bending case. Imagine bending a coke can, when you bend it, it always fails in compression.
You could try optimizing the fuselage (i.e. making it thinner in the upper shell area), which may help a little, but then the fatigue engineer shows up and says with a fa-tigue stress greater than e.g. 110 N/mm² he is not able to show a usable life. This fatigue stress is with an Nz = 1 and at 1 Delta P (i.e. internal pressure differential of 1 which is about 9 psi). The ultimate case has an Nz of 2,5 and 1,5 Delta P (FAR 25). So you could factor this 110 N/mm² up and still be in the area of Fty. In addition there are other cases where the upper shell is also in compression (e.g. emergency brak-ing case) so you have to design a bit of stability, so you can’t get too thin.
The third reason assumed that the manufacturer uses a linear FEM calculation (I did say it was weak). If you reduce a linear stress, which is equal to the Ftu value of 2024, T3 following Ramberg-Osgood principles, you obtain a value below the actual Fty value. The manufacturers FEM program will not allow him to go beyond the Ftu value as he would have an MoS less than zero.
The above probably produces more questions than it answers but I hope it’s a bit of help in trying to explain my point.
Alex,
Only DER's at OEM's have access to this proprietary information. DER's in the field typically do not have load data. Even though I chose the username 737eng, I do not work for the big B, I only chose that name since I have come to enjoy the 737 over the years and it has kept me employed.
The DER finds compliance with the FAR's. In order to show compliance a structural analysis typically has to be accomplished or reviewed. (other data and/or analysis may have to be accomplished as well, i.e. DT, Burn tests, electrical load, emi, etc....however I am a structures DER without DT so I am only showing compliance to FAR's that deal with static strength). A DER has a mixture of both regulatory paperwork and actual engineering.
By the way, I still call them FAR's, however, I believe the correct terminology is Code of Federal Regulation, Title 14 or CFR 14.
When you state bumping up FTU by 15% are you talking about the 1.15 fitting factor per FAR 25.625? If so, the 1.15 fitting factor only needs to be utilized when you are not utilizing tested data for your allowables.
Bazzo,
I feel that the belly and the crown are definetly designed differently to account for the different loading. Typically the belly skins are thicker, plus, the stringers are designed to take the compressive loading.
I understand your statement that the structure never sees FTU, otherwise we couldn't add any fastener holes. However, still feel the key is that since you do not know the actual limit load in the panel, which can be anywhere from (-) all the way up to Fty. You cannot verify that you meet the 1.5(limit load) req'd by the FAR's. Let me know your thoughts on this issue.
If I read you correctly, you're only checking for static strength. Some additional questions:
1. Do you base static strength on Ftu ONLY?
2. Do you ever do a damage tolerance analysis beyond the static strength analysis? Is the static analysis then forwarded to another DER who performs a DT analysis? It would appear that static strength alone is insufficient to show the acceptability of a repair.
3. Are all your static calculations hand-based? If not, what computer programs do you use? Do you use FEA?
4. How does one become a structures DER, beyond the application to the FAA? Is any particular experience or educational level required?
5. Yes, the 15% fitting factor you're describing is what I was talking about. When you write "tested allowables", do you mean that the FAR's require a 15% increase in Ftu if I don't obtain the joint allowables from the SRM or Mil-Handbook 5? Douglas training courses add the 15% regardless. Boeing training courses never do. That said, thanks for listing the FAR number, I'll look it up.
6. When you can't find a joint allowable for a certain fastener/sheet material combination under single shear, do you find it acceptable to use Fbru * d * t (even though Fbru is based on double shear, with less eccentricity?) to determine the joint allowable, provided that the double-shear strength of the fastener is higher?
Thanks for providing some insight.
Alex
No, I base the static strength on the ultimate load carrying capability of the structural member (i.e. skin panel per this post). As can be determined from reading all the above posts, there is more than one way to determine the actual ultimate "running" load of the panel. If I cannot determine the actual ultimate load carrying capability or if I am pressed for time, I will then resort back to using Ftu, knowing this is extremely conservative.
Currently, I typically am involved with pre-ammendment 45 aircraft and therefore do not have to show compliance with 25-571 (b) {don't quote me on the actual FAR). I typically just have to meet the "fail-safe" requirements of 25.571 since that is what the aircraft was certified to. I can show that I meet fail-safe by either evaluating the original design, or the SRM. This will change in the future, since Congress and thus the FAA are driving us into basically making all a/c damage tolerant. However, when I do get the opportunity to work on a DT aircraft, I cannot provide the DT approval. Therefore, I either utilize the guidance of a pre-existing repair (i.e. SRM) or I limit my approval to one-year following the guidelines of AC 25.1529 and then submit to obtain the DT approval (typically the OEM).
Most of my calculations utilize classic "hand-based" structural analysis. I do utilize computer programs, such as ACAD Mass Properties, Virtual DER, excel (build a spreadsheet to do crippling analysis, etc). I do not use FEA software.
The application and requirements are on the FAA website. In general you basically need 8 yrs experience in the area you are applying and have to prove that you are familiar with the FAR's and dealing with the FAA.
Look up the FAR, it provides the guidance you need.
I do utilize Fbru * d * t as long as it is a protruding head fastener or the buck tail is against the sheet. I do not feel that Fbru * d * t is acceptable for countersunk fasteners.
1. Referring to your reply's first answer, and the determination of load capability in a skin panel, I'll repost my comment made to another poster: If you look at a skin production splice on the 717, you'll see two rows of fasteners. The skin repair section in Chapter 53 mandates a minimum of 3.5, sometimes 4.5 rows (with finger doublers) for permanent repairs. If you were to use Ftu, you'd probably end up with 5 or 6 rows. What gives? How does one justify the variation from two to six rows?
2. Don't you think that using Fbru*d*t for a protruding head fastener over-estimates the single-shear strength of a joint, due to the added joint bending compared to a double-shear joint?
3. How do you compute the bearing strength of a countersunk fastener in a single-shear joint?
Alex
There could be multiple reasons for this, which I do not have time to look into right now:
I am not that familiar with the B717, are the skins chem-milled? If so, the thickness of the skin (or added doublers/finger doublers if not chem-milled) is most likely greater than the skin thickness in the pocket (between stringer and frames). Thus due to the reduced skin thickness the fastener bearing capability is reduced resulting in the need for more fastener rows.
You should always use tested data, if not, the 1.15 fitting factor per FAR 25.625 should be utilized. Therefore, if you calculate your bearing Fbru*d*t you will need to utilize the 1.15 which will account for transitional failure modes.
You have to use tested data. I do not know how to calculate it. If you or someone else know how, I would be delighted to find out.
This is a great forum, lots of good discussion. I'll wade in with my 2 cents worth.
As for designing repairs, the use of MATERIAL FTU alone is overly conservative. One approach is to look at a nearby section, such as a skin joint with rivets connecting to a stringer. At this location, the maximum hoop load is based on the NET AREA * FTU. That is the maximum load in that skin panel/bay. If it is a joint, the lesser of the fastener transfer capability or the net section ULTIMATE strength should be used.
Now it was said that Airbus lets one use Fty. That might be a design criteria they used from the begining, and that method should not be transfered to other aircraft. Boeing and other manufacturers all have their own criteria that must be met during design.
later,
jetmaker
1. No, the areas of skins I've delt with (below the cusp line) on the 717 are not chem-milled unlike the Boeing models. However, you are correct in that there are finger doublers at factory skin splice locations thus increasing the local thickness at these locations. Consequently, I agree that the skin thickness in the "pocket", away from factory skin splices, would be relatively thinner. However, why would you size a repair doubler based on the thicker skin thickness at the factory skin splice, when the local thickness to be repaired is relatively thinner?
2. I understand that one must use tested data, when available. However, often enough, you find yourself with fastener/sheet material combinations not found in MIL-HNBK 5 or the SRM. I'd be interested in your comments regarding the overestimation of using the bearing formula Fbru*d*t for single-shear joints due to the added bending, and how you'd go about for correcting for that overestimation.
Hi Jetmaker:
Are you saying that the maximum panel load carrying capability in the HOOP direction is based on the NET AREA (gross area minus fastener areas) of a skin/stringer joint (not necessarily a skin splice location)? What about the maximum panel load carrying capability in the LONGITUDINAL direction?
You then mention "If it is a joint, the lesser of the fastener transfer capability or the net section ULTIMATE strength should be used." I am little confused as to the difference between this and my previous paragraph above when determining the max. load capability of a skin panel (I think it boils down to terminology confusion or rather terminology ignorance on my part :). Could you please clarify the nuance?
A curious Alex
Yep.. you have it correct. The maximum panel capability is based on NET AREA = Gross Area - Hole Out Area. The same applies for the longitudinal axis. But note, this is not necessarily at stringer locations. This could be at a cutout, a row of rivets used in a doubler, or simply the gross area of a chem-milled pocket. Use whichever is less.
Let me try from a different approach with regards to the joint. If you have a 2 row lap joint, calculate the bearing/shear capability of each fastener. Then multiply the total fasteners in the lap by this number. This is the joint strength based on fastener capability. Next, check the NET AREA strength at the first row. Whichever is less is the joint strength capability which governs your design loads.
Hope this helped.
jetmaker
Let me see if I've got this straight...
1. Essentially, you're saying that the max. NET AREA (i.e. material-based) load carrying capability of a skin panel is the smallest NET cross sectional area (Net Area_min) at ANY LOCATION in that panel (whether it's a skin splice location, a stringer to skin attachment location, etc.) times Ftu? Choosing the smallest net cross sectional area gives the maximum load that can be carried by the MATERIAL at any location.
2. Then, you compare it to the min. load carrying capability by the fasteners at any joint location on that panel (If you have two rows of 50 each -6 rivets at a butt joint along the panel, the max load carrying capability by the fasteners in that skin panel is 100 * Pall of a single -6 rivet in that sheet material/thickness). Choosing the minimum load carrying capability at any joint location on the panel gives the maximum load that can be carried by the FASTENERS at any location on the panel.
The lesser of the two (Net area_min*Ftu vs. min. fastener load carrying capability) is the strength of panel? In other words, the lesser of points 1 and 2 gives the maximum load carrying capability of the panel?
Did that sound right?
Cheers,
Alex
Sounds like you have a good understanding of the approach I use. However, just to clarify a few things. 1) the definition of panel in this case is a localized region of the skin, defined as a small region between frames and stringers. You can not use a lap joint capability to analyze a portion of the skin 5 stringers above the lap. 2) the strength of each panel must be calculated in each direction independantly. So, do not use a lap joint to calculate the tensile capability in the hoop and longitudinal direction. Make sure you choose wisely.
jetmaker
Questions are numbered 1 to 6.
1. So, you only use a lap joint to calculate the tensile capability in the same direction as the lap joint? (i.e. if the lap joint runs fore-aft, the lap joint will give you the hoop tensile capability only?) For the longitudinal tensile capability, you might use a factory skin splice butt joint or even just Ftu is no splice joints are nearby? What about using a frame's net area (net area of skin minus fasteners' area common to skin & frame) or total fastener capability (Pall of skin/frame single shear joint), whichever is lower, to get the longitudinal tensile capability?
2. Could you digress a bit into "You can not use a lap joint capability to analyze a portion of the skin 5 stringers above the lap"? Say you'd want to find out the tensile capability of the that local area five stringers above the lap joint (considering the lap joint runs fore-aft):
You'd have to use the lesser of the net area*Ftu AT the stringer along that panel's length OR the total fastener capability (Pall of skin/stringer single shear joint) along that panel's length AT the stringer? In both cases, the stringer is the closest attaching structure to the skin near the local area of skin to be repaired. Is that correct?
3. However, if the "local" area to be analyzed was right above the lap, it'd be okay to use the lesser of the lap joint's net area*Ftu OR total fastener capability (Pall of the lap joint) to obtain the max. tensile strength of that local area in the hoop direction?
4. It would appear as though the hoop tensile capability near a lap joint would be higher than near a stringer since you might find higher skin thicknesses around lap joints, as well as a minimum of two rows of fasteners at the lap joint, versus a thinner skin and only one row of fasteners through the hat section of the stringer. Any comments?
5. Last point may sound trivial but I just want to make sure: Say you're above the lap joint as described above. So you use the lap joint as the reference for obtaining your net area*Ftu and total fastener load (you take the lesser of the two). Obviously, the lap joint runs for a good length along the skin panel's length (say 100 inches). Now, your cutout is only 10 inches in length. You'd only use 10 inches of net area for your material capability, right? Likewise, when calculating the total fastener capability, you'd only multiply a single fastener's joint allowable strength (Pall) times the the number of fasteners contained above the cutout within a 10-in length segment, right?
6. Say you need to cutout part of a beam's web. Instead of using Ftu, would it be acceptable to use Fsu (much lower than Ftu) for doubler sizing since the loading in the web is primarily shear?
Hope my questions make sense. It's late. Looking forward to reading your answers.
Alex
