Sherdding & Pyrolysis of Used Tires
I´m working on a feasibility project for a tire pyrolysis plant. I´d be thankful if some of you could tell me where to look at about reactor types and cost analysis for shredding equipment.
Cheers, Jaume
Cheers, Jaume
RE: Sherdding & Pyrolysis of Used Tires
Pyrolysis is the one process I would certainly NOT recommend and the reasons are dioxins and furans. You want to heat the fumes to 900°C for 4 seconds in air to break these chemicals down.
remove.marius_che@yahoo.com
