Cold-rolled versus hot rolled mild steel
What is the advantage of using cold rolled mild steel (round stock) when compared to hot-rolled? Traditionally we've used cold rolled for items like linkages or lightly loaded machined parts; and hot rolled for fabricated parts and weldments. The purchasing guy here says there's no difference except for finish. I disagree but have found little proof to back my arguement!
RE: Cold-rolled versus hot rolled mild steel
HRPO 1020
Elongation ~25%
Ultimate ~55.1kpsi
Yield ~29.7kpsi
CRS 1020
Elongation ~15%
Ultimate ~60.9kpsi
Yield ~50.8kpsi
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Then there is the surface finish issue. What kind of roughness can you tolerate?
Then finishing over scale vs bare metal in some applications.
MadMango
You can get a lot of properties and tolerance information at:
http://www.ryersontull.com/stocklist/RedbookServlet?COM=GetLevel&ID=DATA
