Addition of Acid/Alkaly for neutralisartion
Is there a way available for estimation of quantity required of acid/alkaly solution for neutralisation of an aquos solution having a pH of alkaly or acid side. More specificaly a method based on pH alone and not on lab analysis?
thanks
thanks
RE: Addition of Acid/Alkaly for neutralisartion
'Alkaline pH neutralization'
Thread161-61126
*This will be a minimum value; the more dissolved and suspended solids in the system, the more likely it is you will need additional neutralizing agent. This is because the solids have a buffering effect on pH which must be overcome.
