Improving color in water
I am trying to find a method for improving color in water. The color in the water is not particulate matter or suspended matter. It has a slightly brown color that needs to be improved. We don't have a ton of details on the color only that it is brown colored water.
Can this be improved using any means of filtration or active carbon?
Are any other methods used for improving color?
Matthomas51
Matthomas51
RE: Improving color in water
Do you wish to make it a light or a dark brown?
Would sugest that you have an analysis done on a sample first.
This brownish color could be due to presence of colliodal particle in water, otherwise not detectable by ordinary alanytical methods for Suspended Solids or Turbidity.
I may suggest you some remdial actions, once the nature of the impurity, generating color in water, is determined. Do you have any pre treatment system installed at your facility?
Regards.
Ansari
<nbucska@pcperipherals.com>
Good luck.
the usage may tell us which means are acceptable for treatment.
