Permanent wearve from from end !!
I have a zzr-600 model E1 (1993). There is a persistent front end weave. So far, I have bought new Hagon rear suspension and progressive front shocks, new head stock bearings, new disc brakes, new wheel bearings and checked tyre pressures (do this daily). The frame does not appear to be bent, what other suggestions do folk have and has anyone else had this type of problem ?????
It's getting desperate now !!!
RE: Permanent wearve from from end !!
I am surprised that a 90's anything should suffer from such basic handling deficiencies.
Rod
Without a more precise description of the problem - speed range it happens in, on the brakes, on the gas, over white lines etc it's very hard to diagnose any handling faults.
I suspect that if everthing else on the bike is eliminated as a cause then you could have frame damage you don't know about.
Otherwise, the cause may be due to the type of tyre, or alignment, or head bearing adjustment, or ...
Harvey.
