DL05 SOFTWARE WONT ALLOW FORCES
Help,please.
I just started programing a few weeks ago.My problem is,I have a Direct Soft DL05 PLC that I am useing to practice on and the force option or (overide) is not highlited.It was the last time I used the software, can anyone tell me how to get it back?
             Thank You.
RE: DL05 SOFTWARE WONT ALLOW FORCES
Are using the directsoft 32 software? I f so, i can help you. I can't remember off hand the procedure for enabling forces, but I will get online with the PLC tomorrow to let you know. I am using a dl 305 cpu in a project on the assembly floor. Provided that you are using direct soft 32, the procedure should be the same. best regards, plcsavvy
Check out:
http://Forum1.automationdirect.com/cgi-bin/Ultimate.cgi
I don't beleive the DL05 has forcing capability!!
