Temperature of Molten Metal Bath
In a 3000 lb. bath of molten iron what kind of thermal gradients would you expect to see (if any) from the surface to the bottom? The top of the vessel is exposed to ambient air and the bottom and 4 sides are steel lined with alumina refractory. I am taking temperatures from the top of the bath using an immersion thermocouple and am getting around 2550 F. The metal stream pours from the bottom of the vessel. Will this stream temperature be hotter than the surface temperature?
RE: Temperature of Molten Metal Bath
Maui
Melting -- Coreless induction furnace
Vessel is non-heated
Slag is removed after filling the vessel
No mechanical stirring action
New iron is added every 8 minutes
TTFN
Maui
