"Hidden" view with solids
I'm working with the same file (all solids) on two different machines both running ACAD 2002.
On one, when I'm in "Hidden" view, it does just that. I only see the visible edges of the solid parts. On the other machine, though, I also see a bunch of lines connecting various edges to other edges. It's pretty annoying.
Is there a setting to turn that off?
RE: "Hidden" view with solids
Try this,
command: DISPSILH
and change the value...either (0 or 1)
The issue arises upon the command "shademode _h", not on "hide" command.
To be more descriptive, here's an example.
I have a block with a bolt-hole pattern in it. There are many lines connect the holes together along the X & Y axes, and connecting the holes to the corners of the block.
I see them on a machine running Win 2K but not on the machine running Win XP. I don't know any details about graphics cards, etc.
