File list to Access
File list to Access
Hi There!
May be here is not exact place for looking for a answer but:
Have the problem.
How can I Make a table in Access that will look for a files *.dwg in a subfolder named "SUB".
Just A simple file storage but I can not find the decision
ZMEI
Have the problem.
ZMEI
RE: File list to Access
1. Make a batch file (*.bat) which contains this text for example:
dir c:\sub\*.dwg/b >c:\sub\dirlist.txt
2. save it say on c:\sub\dirbat.bat
3. prepare RunApplication on macro with command line c:\sub\dirbat.bat
4. Run macro
5. Attach the text output dirlist.txt as linked table.
209larry
