Driveway (part.) slap replacement details
A concrete contractor has recently replaced a small (13'x13')defective section in very large new residential driveway.  The problem is that they did not saw cut the edges or work back to a control/expansion joint and simply jackhammered out the slab and repoured it with very rough edges.  The must be some standard practices that restrict this type of work. Can you cite or reference any standards?
