Thermal Cycle Test setup Question
I have a copper conductor through a Cycloalophatic resin that I want to run a thermal cycle on for expansion and contraction of both materials to see if they fail. Does anyone know a standard test procedure as far as number of cycles and time duration. I have a min and max cycle temp.
thanks in advance.
thanks in advance.
RE: Thermal Cycle Test setup Question
The best test is a functional test simulating what the parts will see in service. This could be cycling current flow in the conductor with an external cooling means to create the thermal interaction.
