Tolerance num digits
Dear all,
Can the number of digits in the tolerances be less than in the nominal value, i.e. I want the nominal val to be one decimal place and the tolerances to be to two decimal places? I know that by defualt it is not possible.
We are using 2001
We are using 2001
RE: Tolerance num digits
Perhaps you mean to say that you would like to have the trailing zeros displayed for the nominal and hidden for the limits?
If the limits have 2 places then the nominal has to have at least 2 places. I worked with a draftsperson that could not understand why the dimension needed to have 3 decimal places when both of the limits only have 2 decimal places. The reason for this was that the limit dimensions were not displaying trailing zeros, but in order to have the needed limits the nominal had to have 3 places or there would be rounding errors.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
