Using SolidWorks for aerospace sheet metal??
Can SW be used for layout of wing ribs, spars, intercostals and such? We are using Microcadum 2d for our layout now but want to go to 3D solids. I use MasterCam and Catia V-5 for solids on mechanical items, i.e. forgings, castings, cnc type of parts. SW seams easer to use than Catia but is it as powerful. Any input would be helpful on these systems, we are in the search and demo stage of our decision process.
Thanks for the help
Larry
Thanks for the help
Larry
RE: Using SolidWorks for aerospace sheet metal??
I know that Unigraphics and CATIA are capable of handling aerospace geometry. If you have CATIA, I'd say tough it out and learn to use it to the best of your (and CATIA's) abilities.
High-end modeling capability comes with enough rope to hang yourself. CATIA may be a bit cumbersome, but is far more capable where it counts for aerospace and automotive.
Thanks again
I'm looking at this for a very different application than you are, so not sure if suitiable for you. If you call Aerohydro they will set you up with a fully functional trial version. Been working with one of their engineers on a specific problem. Very helpful and competent.
