Deburr Standard
Deburr Standard
Deburring seems to be a process that's different
from company to company.
Does anyone know if there's actually an industry
standard? Or can someone suggest a source of a
good general overview of deburring?
I tried a web search and the result was mostly
vendors with various devices to sell.
Thanks for any input...
Pete
Pete
RE: Deburr Standard
http://www.abrasiveengineering.com/bkdebur.htm
RE: Deburr Standard
http://archive.metalformingmagazine.com/1996/12/6mfdec5.htm
RE: Deburr Standard
RE: Deburr Standard
Break all sharp edges .010 max.
A note like that normally will get the attention of the machinist or shop supervisor.
RE: Deburr Standard
manual debur
time saver
heat flash
tumble
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Deburr Standard
http://www.abrasiveengineering.com/bkhandd.htm
RE: Deburr Standard
organizing training and putting together a
formal procedure. I'd rather use an industry
standard than "re-creating the wheel".
More specifically the application is a stamped
hole through an aluminum extrusion.
There a reluctance to deburr multiple holes by hand,
but then using an air tool seems to remove too much
material. I'd specify a dimension, but the process
personnel aren't machinist...
Has anyone tried the Burraway tool, [aka: clothspin
deburr tool]?? see:
http://www.usatco.com/deburring_03.asp
Thanks again...
Pete
RE: Deburr Standard
RE: Deburr Standard
They use a similar tool now. The operation requires
deburring hundreds of holes, so I'd like to find a
more automated method.
Pete
RE: Deburr Standard
Bob
RE: Deburr Standard
Yes, they tried a chamfer tool with a drill stop and somehow
always manage to remove too much material. I'd like to find
a fail safe way to process multiple holes.
In the interim I may try the burraway tool.
Thanks for all the input...
P.
RE: Deburr Standard
Thread404-35606
RE: Deburr Standard
as to various thicknesses of materials, the reason
for deburring callout. Is it for removing stress
risors or just to allow for a radius to form
after coating or plating? Will it be done by
hand or automated?
Is it cosmetic and just to remove sharp edges for
assembly? Is it an external surface or internal
surface that may need a sharp edge? Is it an interface
surface and on and on?
If your deburring method removes too much material
on a hole, why not call for the holes to be undersize
before deburring?
RE: Deburr Standard
RE: Deburr Standard
RE: Deburr Standard
