Programming: Get Coordinates in Model View
Does anyone know how to determine the coordinates in model view when the Solidworks window is active even if nothing is selected? I am trying to relate mouse coordinates to the 3 dimensional coordinates of the model view window in solidworks. Thanks for the help.
RE: Programming: Get Coordinates in Model View
Someone said I would need to make use of a subclassing method to do this, but that is a very advanced and not-so-simple method of VB programming.
I was working on a macro that would insert a component into an assembly by just typing in the part number (no need to browse to the component). Problem was, I could not convert the mouse position coordinates to model space coordinates when the user clicks the mouse in open space (like the regular 'insert component from file' works).
I ended up requireing the user to click on the model to get a 3D point in model space for my macro as a location to insert the component. If nothing is selected, the component is inserted at 0,0,0.
Again, PLEASE let me know if you make any progress.
Thanks.
I'm knackered just thinking about it...
