Sulfur Mist Problem
Sulfur Mist Problem
Sulfur Mist Problem
Hello All,
I need yr help for solving the sulfur mist problem.The gas(consisting of H2S traces) coming form Sulfur Recovery Unit enters our packed column for further H2S processing. So there might be presence of sulfur mist from the sulfur condenser(part of Sulfur Recovery Unit), The presence of mist may cause problems in our bed and hence reduce the efficiency.Are there any means by which we can eliminate the mist such as use of coalescer/mist eliminator.
sj
