Extension Lines
Extension Lines
Extension Lines
I know how to slant the extension lines in a drawing but that makes the extension lines parallel, is there any way to make the extension lines slant toward each other in SW2003?  I'm dimensioning the gauge diameter of a tapered shaft and it would look better if the extension lines slanted toward each other.
mncad
RE: Extension Lines
One possible technique:
Download zip file from this page:
http://rschwarz.tripod.com/CAD/TaperedShaft.htm
This is a method for sketching lines on a view for use as extension lines.  Note use of vertical and horizontal constraints on enpoints to keep sketched curves associative with model geometry.
Good and evil: wrap them up and disguise it as people.
