Ansys Documentation/User's Guide
  I'm a new user of Ansys. Would like to know where can i find online documentation and user's guide for Ansys 7.0. Thanks!
RE: Ansys Documentation/User's Guide
If you've got ansys installed its already on your machine.
Just bootup ansys and goto help.
Otherwise the latest I found was a 5.7 manual online.
Thanks for the advice, but the problem is that my computer with the ansys installation has no internet connection.
Ummm....so how are you going to get online manuals without a connection????
Ansys uses Javahelp in v7 to display its help.  This is not dependent on any internet connection whatsoever.
Alternatively you can use the inbuilt microsoft help system by deleting the Javahelp environment variable (if a windows system) or by setting Javahelp = 0.
hi, thanks a lot Stipity for ur advice. seems like i can't access help because there was some config problem. managed to solve it, thanks! :)
