How do you draw a 3-d thread and a 3-d spring in solidworks
Hi all,
I have solidworks2000. How do you draw a 3-d spring and a 3-d thread.
Better yet if one is already done I like to get a down load of it.
thanks
blau
thanks
blau
RE: How do you draw a 3-d thread and a 3-d spring in solidworks
A spring and a thread are made in the same fashion.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
http://rschwarz.tripod.com/CAD/TorsionSpring.htm
Basically, threads and helical springs are made by sweeping a profile sketch about a helix. You can find information about how to make a helix in the help file. It starts with a 2D sketch of the helix diameter.
For the profile of the sweep, use a sketch on a plane that is normal to the helix. Create the plane by using "normal to curve" in the plane tool, selecting the helix endpoint and the helix curve. Then use Insert --> Base/Boss --> Sweep to create.
When using a helix for a sweep, I find it useful to make a copy of the helix using 3D sketch and convert entities. The reason for this is that if a helix curve is used as a guide for a sweep, the endpoints of that curve become unavailable to select for future reference.
For screws, please if you are not already doing so, do yourself a favor and make a simple revolve whenever possible. Only use a true helical thread when you absolutely have to.
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
We'll raise up our glases against evil forces.
Whiskey for my men, beer for my horses!
T.K.
tatejATusfilter.com
Since you can't Download my files because they are made in SW03 (Just realized you are on SW00) You would have found a bolt that had 2 configurations. 1 config showed you how to make a true thread with a Helix. The other one showed you how to make fake threads, which are better like TateJ has pointed out. All you have to do there is create a revolve extrusion around the body of your bolt with a thread looking profile.
With Springs, yes they can be tricky but the same concept is still there as with threads. If you are making a spring like a bed frame spring then yes those are harder. Because you have to make not only the helix, but before you can extrude a profile along that helix, you have to make each end then turn the whole path into a composite curve so you have one entire path.
If you go to the SW website and log in under subscription support I'm pretty sure they have some and I think they are from older SW packages.
Scott Baugh, CSWP
FAQ731-376
http://www.solidworks.com/pages/services/subscription/modellibrary/listmodels.html?C1=Modeling%20Techniques&C2=Sweeps
