gas turbine tripping
Friends,
We have gas turbine driven compressors of Solars make.Recently we have had problems of ignition failure/explosion sound during ignition step of start up/fuel gas valve fail alarm. Does anybody face this problem frequently with SOLAR make turbines? Any specific solutions to this problem,Thanks in advance
hiren
hiren
RE: gas turbine tripping
I THINK THAT YOU SHOULD CHECK THE FUEL VALVE WHICH MUST BE OPENING MOMENTARILY & THEN CLOSING .AFTER SIMULATION FROM C & I CHECK FUEL VALVE OPENING.
