Aluminium washers from sheet
Hello Engineers,
I want to make 1" O.D. X 10 mm I.D. washers from
5 mm thick aluminium sheet. How much minimum gap should be
kept between two adjacent washers while pressing.
What is the maximum number of washers that can be pressed
in a single shot. I have a mechanical press of 50 tons.
Thanks in advance for your replies.
Best regards,
Bhavesh Dhruve
Best regards,
Bhavesh Dhruve
RE: Aluminium washers from sheet
