Equivalent Wire Sizes.
Anybody kindly furnish me the standard where I can justify
that equivalent sizes for wire size 4mm2,6mm2, and 10mm2 are respectively AWG#12,AWG#10,AWG#8.
RE: Equivalent Wire Sizes.
This has been discussed recently.  Do a search...
Mike
It has been discissed in the electric power engineering under the title of cable sizes posted on July 5, and last reply was July 13. This is the link
Thread238-62618
You can also find what you want in this section uder the name
european wiring codes
Gabi
Look in the National Electrical Code (NEC), on page 70-625, Table 8, Conductor Properties. For wire sizes from 18 AWG to 4/0 AWG, the area in mm2 is listed.
