Dimensions on top of leaders
I am using SW2001 plus. When I dimension a horazontal feature in a drawing SW's puts the dimension on top on the leader instead of in the leader. I have changed the setting in the Document Properties Detailing Dimensions but it does not seem to take. Any ideas?
RE: Dimensions on top of leaders
Check the properties on the individual dimensions.  Maybe they got hanged from "use document default"
I may make you feel, but I can't make you think.
Check the display of the dims like TheTick specified above by RMB the dim\Properties\Display
Just to make sure...You did change the
Tools\Options\Document Settings\Detailing\Dimension\Leaders
to the correct options you want...right?
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
