Changing Drawing Format
Dear Folks;
Is it possible to swap the drawing border of an existing solidworks drawing with a new drawing border ?
How is this done ?
Best Regards
Adrian D
RE: Changing Drawing Format
Right-click on the white space of your drawing (don't active a drawing view), select Properties, under Sheet Format select Browse.  Browse for the new border.  Don't forget to change your sheet size if required.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Beat me to it, MadMango.  But it does ilustrate somthing about SW which is really useful.  I have to keep reminding myself to do it even now (we started on SW 97).
SW was written Window native.  It uses the standard Windows methodology to the max (yeah, I know - good AND bad).  Whenever you need to know about or change the properties of any "object", always try a right-click!!!
3/4 of all the Spam produced goes to Hawaii - shame that's not true of SPAM also.......
