xref/lisp
xref/lisp
hi, i tried to get list of points, stored by the in xclip function in each clipped xref
i havent found antything about it (not documented?).
does anybody know hot to reach this coordinates?
i tried with vlisp and lisp
RE: xref/lisp
And no luck.
Although, you could retreieve the points once you generate a polygon from the XCLIP, which is one the options in XCLIP.
I think that the best you can do.
Unless you can crack the code that the POLYGON uses to get the shape from XCLIP.
Sorry I couldn't help.
